I want to start recording my first Let's Play videos for YouTube today if possible, and
I'm wondering which recording software I should use.
I need a recording software that is free to use, that has no video lenght or file size limit, and that will allow me to record audio from both the game and my mic simultaneously.
I already have FRAPS which supposedly fulfills those requirements, but can be bad on frame rates. I'm going to do XCom:Enemy Within and have a pretty good rig so frame rate issues shouldn't be too bad in this case, but they may be on another games. So maybe I should start with Fraps, or already start with some software that is better for more graphically demanding games?
I also could use Nvidia Shadowplay, but there is a limit for file sizes I understand. I need to be able to record at least 45 minutes at a time.
Also, if I use the program you recommend, will I be able to edit the sound channels separately so that I can set the video sound volume separately for mic and in-game audio afterwards when the video is already recorded?
One more question regarding mics; I'm not after studio quality sound, I just want something cheap and easy, and I tend to move around a bit when I play, so a headset mic or one that can be attached to my current headset would be nice. But how does the mic connect to the PC on a headset combo unit? I have never had a headset that has an in-built mic so I don't know.
Also, are there any other special considerations on how to record the video/audio when releasing them on Youtube?
