You made no mention of cooling. You might try making some cooling improvemnts. But, probably the main thing holding you back is the memory. PC2100 using a 1:1 ratio is only rated for 133 MHz. Obviously, most will do better than that, but 150 MHz is probably asking too much out of it. Try backing off on your memory settings a little (like using a 5:4 ratio).
