I've had this CPU for about 5 months it is a AGIOA - 4 it peaks at around 60c on the on die temp on my Epox my mobo temp rages from 26-30c. I have it running at 1.9v it is 100% stable at 1743 10.5x166 I really want to push it father but it gets very unstable at anything higher than this. My temp seems pretty high to me for what I'm running I have a Glaciator 2 on the chip which isn't great but it should give better reults than it is giving. Also my Enermax 5v line is somewhat low often times dipping into the low 4.7 range. What do you think the problem is or is it a combo? Please help me get higher.
Thanks
Shawn
Thanks
Shawn
