help me pick
almondboy72
Disabled
chicago
okay well i have 100 most likely the max to spend on a mobo and i want something with nforce2 and amd involved into it and alot of space to handle alotta ram 3200 and up and all my gaming needs come on OC lets see what you can come up with if you pctures and links even better.
everclock
Chicago
are you just buying the mobo with that $100?
If so, here is a decent board
zipzoomfly
OSUmaxx
Senior Member
Oregon
I highly recommend the Abit NF7-S, which you can now pick up for $100. It overclocks very well, has PCI/AGP lock, and a load of features.
