- Mar 13, 2005
Just got this awesome unit for my Case (Extraction), it's currently paired with a SilverStone FMC3XW (White) 120mm Dual ball bearing Case Fan + Controller
Have got it purring in XP @about 40% on idle using Speedfan.
Problem I have is I have nothing that will control it. Neither the Zalman Fanmate2 nor my current fan controller Akasa AK FC-03 Fan Controller Pro (OA-002-AK)
Have the legs to Tame this fan :-
Rated Voltage 12 Operating Range 7-113.2v Rated Current = 2A Rated Input Power 24W if i run without Speedfan Ie outside windows.
Ideally I'd like to add a fan control of the sort that ships with the silverstone that I could add to this 31/2" Modded Fan Bay 1st is 120 S/Stone in bottom of Case(Intake) 2nd is 80mm on Side Panel. I would then ditch the Akasa(looks pretty that's about it)
I've spent most of today searching for something suitable, this forum, reding the stickies appears to be the most knowledgeable place to help me.
I'm a total newbee when it comes to matching the requirements of the fan with the necessary control & it's more than a few years since I forgot what my physics teacher said
Have tried a forum search on Delta but could find no specs or suggested parts for a suitable fan controller.
When I reboot it's awsome , but the wife can't hear the TV & it frightens the cat's . Have got some extra memory I want to try Memtest with but daren't at the moment Hehe!!
So you can see my need for help
Thanks
Thanks
