HElp me with my HDD ?
DDR-PIII
Disabled
6p6
Ok I can't format my C: drive.... It looks like it formating then it gets 100% done and then it says "ERROR CAN NOT WRITE BOOT" the reason I'm trying to format is bcause I got the ERROR message saying that HIMEM.SYS was corrupted can you help me please ?
AntiHeiss
Senior Member
Texas
A couple questions so I can get a better idea.
1. Are you using any type of virus monitoring software or the like?
2. Is your system overclocked when you try to format?
3. Do you ever get any other errors?
4. Have you tried to format the drive in MS-DOS using FDISK?
Thanks
DDR-PIII
DDR-PIII
Disabled
6p6
1. Are you using any type of virus monitoring software or the like?<---NO
2. Is your system overclocked when you try to format?<---NO
3. Do you ever get any other errors?<----NO
4. Have you tried to format the drive in MS-DOS using FDISK?<---YES
Thanks
DDR-PIII
DDR-PIII
Disabled
6p6
Or cant I just copy the HIMEM.SYS file from another computer? or they all arent all the same ?
