My Existing PC:
Pentium II 200Mhz MMX (overclocked to 233)
196Mb Ram Simm
4mb graphics Card
My upgrade to make:
AMD Duron 800Mhz
128Mb SDram P133MHZ
QDI ATX Motherboard KINETIZ7T
ATX MIDI Tower Case ATX4010-6
300 Watt Power Supply 300VAPSU
TITAN Heatsink and Fan 579672H
S3 Trio 3D 8MB Video Card - AGP Interface
Should I get an AMD Athlon 700 instead? (its slightly more expensive)
Should I go with the ABIT KT7 Raid instead? (This is quite a bit more and i have to downgrade to 100Mkz ram)
I have a standard compaq motherboard. Do you think I should get a new socket 7 motherboard(if so which one), an AMD K6-2 550 and keep the ram?
I have enough spare bits to make the upgrade into a whole PC, therefore I will have 2 PC's.
I am not that familiar to overclockin as i got my 200 up to 233 by doin
nothin but flickin a switch on the motherboarc
How much could I overclock this Duron? Could I get it up to 1000 fairly
easily?
Would 128 SDRAM be faster than my old 196Mb Simms?
Anyone ever bought a QDI motherboard before?
8mb graphics card - is that enough for a low budget student?
I want to network these two together - is it worth buying a hub, or just connect the 2 together?
I built the PC above myself, and i am quite knowledgable about all off this
stuff. This will be the last upgrade I will do for a while as i am a
student. This is costin me a good bit, so I dont want it to go wrong.
I would appreciate all of your feedback. Please help a poor student who is splashin out!!!
Thanks,
Mark.
P.S all suggestions for products have to be available in Europe!
196Mb Ram Simm
4mb graphics Card
My upgrade to make:
AMD Duron 800Mhz
128Mb SDram P133MHZ
easily?
Thanks,
Mark.
