Hi Guys,
I was hoping someone could help me with my first attempt ever at water cooling a new PC I built. Any help would be greatly appreciated.
My current build is:
1. EVGA GTX780 Classified 3GB GDDR5 / ACX Cooler X2
2. ASUS Maximus VI Extreme Intel Z87 LGA 1150 Motherboard (should have gotten a Z97 but now it's too late...)
3. Thermaltake Toughpower Grand 1200W 80PLUS Gold Certified Modular Power Supply
4. Corsair 760T Mid Tower ATX Case
5. Corsair Dominator Platinum 16GB 2133MHz (2x8GB)Modules
6. Intel Core i7-4790K LGA1150 4GHz Processor
7. BenQ XL2720Z 27" Pro Gaming LED Monitor, 144hz, 1920x1080 Resolution, 1080P,12M:1 DCR, 1ms RT, VGA,HDMI,DVI
8. Samsung Electronics 840 EVO-Series 250GB 2.5-Inch SATA III Desktop Kit Version Internal Solid State Drive MZ-7TE250KW
9. WD WDBSLA0040HNC-NRSN 4TB 7200 RPM 32MB Cache SATA 3.5" Internal Hard Drive
After watching many videos and reading several threads on watercooling I am still not quite confident that I know what I am doing. I want to overclock as much as possible and my current idle temps are horrible (40c with H100i at stock speeds, HT and turbo disabled!). I don't even want to go into how bad it is under full load...
After looking at different brands it seems as though EK would be my preferrable choice because it actually has a block designed for my GPUs and motherboard. Not to mention, I like their CPU block the best. I started shopping and before I commit was hoping someone here would be gracious enough to help me.
Here is what is currently in the shopping cart:
1. EK-Supremacy Clean CSQ - Full Nickel (http://www.ekwb.com/shop/ek-supremacy-clean-csq-full-nickel.html)
2. EK-FB ASUS M6E - Nickel (http://www.ekwb.com/shop/ek-fb-asus-m6e-nickel.html)
3. EK-FC780 GTX Classy - Nickel X2 (http://www.ekwb.com/shop/ek-fc780-gtx-classy-nickel.html)
4. EK-FC780 GTX Classy Backplate - Black Rev.2.0 X2 (http://www.ekwb.com/shop/ek-fc780-gtx-classy-backplate-black-rev-2-0.html)
5. EK-CSQ Fitting 13/19mm G1/4 - Nickel X10 (http://www.ekwb.com/shop/ek-csq-fitting-13-19mm-g1-4-nickel.html)
6. EK-BAY RES D5 Vario (incl. pump) (http://www.ekwb.com/shop/ek-bay-res-d5-vario-incl-pump.html)
7. EK-CoolStream RAD XTX (360) (http://www.ekwb.com/shop/ek-coolstream-rad-xtx-360.html)
8. TUBE PrimoChill PrimoFlex™ Advanced LRT™ 19,1 / 12,7 mm - Bloodshed Red RETAIL 3m (http://www.ekwb.com/shop/tube-primo...ttm-19-1-12-7-mm-bloodshed-red-retail-3m.html)
9. EK-Ekoolant EVO Blood RED (concentrate 100mL) (http://www.ekwb.com/shop/ek-ekoolant-evo-blood-red-concentrate-100ml.html)
10. EK-FC Bridge DUAL Parallel (http://www.ekwb.com/shop/ek-fc-bridge-dual-parallel.html)
11. Corsair Air Series SP120 (CO-9050014-WW) 120mm PWM High Performance Edition High Static Pressure Fan (Twin Pack) X2 (4 fans total so I have 1 extra)
Am I forgetting or doing something wrong here? Budget is not the biggest issue but I would like to keep it under a grand if possible. I also know that it might be a bit much to jump into for the first time but that is just what I want to do
