- May 21, 2008
Im new to the overclocking scene, and i had a few questions.
1. what is the max temp your overclocked cpu should be at. and what would be a good range.
2. where can i find a easy to understand or "Dummys" guide to simple overclocking
3. Whats the deal with Memory and the "Timings" do i want them higher or lower and whats with the cas lag.
4. How would you rate my soon to be budget build
Case: Sunbeam Quarterback
http://www.newegg.com/product/product.asp?item=N82E16811166035
Mobo: ASUS M2N-SLI
http://www.newegg.com/product/product.asp?item=N82E16813131246
Vid (2 SLi) ASUS EN8500GT
http://www.newegg.com/product/product.asp?item=N82E16814121094
Pcu: AMD Athlon 64
http://www.newegg.com/product/product.asp?item=N82E16819103198
Ram: G.SKILL 2GB (2 x 1GB)
http://www.newegg.com/product/product.asp?item=N82E16820231098
I would like to be able to play Crysis on med settings and planing on overclocking so get my money worth. but the only part i have right now is the Mobo. If anyone has any tips please feel free to let me know
Mobo: ASUS M2N-SLI
Pcu: AMD Athlon 64
