help...my A7V133 won't post
Vector
Baton Rouge, LA
can someone help me with this...
it's been a few weeks since i've messed with my computer and i just decided to quit neglecting it
i turned on the computer, went into bios and tried to enable a few things to increase performance that i had never tried before:
-Switched Video Memory Cache Mode to USWC
-enabled AGP Fast Writes
the rest of the changes i made were fairly common things that i had previously done
after i saved the settings and rebooted...nothing...no post, no beeb...i tried shorting the cmos pins and still nothing...the only thing i can see is that my Leadtek GF2 GTS doesn't like USWC mode...
anybody have any suggestions on how to rectify the situation?
Vector (Aug 04, 2001 04:41 p.m.):
Im having the same problem And cant figure it out I get a bios beep then it just off.
I have done alot of checking and the A7V133 does not support AGP Fastwrites and if your video card does not support USWC dont change the setting.
try doing a shortcircuit on the soldering points and later, remover the battery
good lucky
I have that board and had many many a time when the system would not post from changing BIOS settings. Try to manually set your cpu speed using the dipswitches, so your BIOS will detect a change has been mae and boot you directly into the BIOS
Hope that helps:D
Leaff
Yeah those A7V133s are picky boards i used the jumper settings on the board and it was more stable then using adjustmenst in BIOS im sure glad i don't have that board anymore. try using jumpers on the board better. Good luck
