Ah thanks! Althought, I may have bigger problems....
A few min ago I decided I better put the side of my case back on. It's about 1/2 way on, and sudnelly the computer just turns off. I am like oh ****!!! I remove the side and look in, and everything appeared fine, nothing was bumped, etc. So I put the side on again, and close it all up. I go for the power button, and notice it's glowing amber... I have never seen my computer glow amber so I push it, nothing, hold it in, nothing. So I went around to the back of my computer, unplugged it, and plugged it back in. Came to the front, hit the button and the amber light came on, same thing coulden't do anything. Repeated that, and I still got the amber light. I was like WTF??
So I remove the side of the case, press the button, and it works and it started going it's rebooting thing... I yell a few times, then on the third reboot it starts windows....
and here I am
EDIT - And remember how I said my drive was heating up? Well with my side off earlier, it went all the way to 48*C. But I just realised, that's my second hard drive getting that hot, not my master HDD. So for now the slave is off just so it doesn't get so hot.
