- Nov 29, 2001
Ok, This problem has costed me endless times of sitting in front of my computer, and lot's of my own time.... But I just can't figure it out!!!!!!!! My friend also has the same problem...
Ok, here the problem, I tried to reformat my HDs, both on raid, but my friend don't use raid. Anyways, After I format them, and when I check the disc space in dos for both of the HDs, it came out something like 514,989,982 MB Which is like 514 gigs. I've done the format twice already for both HDs, and it didn't fix the problem. I was using Format C:
And without fixing this problem, I can't install windows or anything. Does someone know of this problem and how to solve it???? I really need help on this one... I've spend too much time on it already...
Please tell me what I can do to try to fix this problem!!!!!!
Ming
Ming
