- Jun 9, 2002
- Omaha, NE/Ithaca, NY
I just got my watercooling system installed, and my temps suck. MBM5 reads 58C at full load and 48 at idle. These are worse temps than with my HHC-001! My system is fully bled, waterblock cranked down evenly, AS3 applied, etc. Here's my setup:
Aquastealth Jagged Edge Waterblock
Aquastealth Northbridge block
Maxijet 1000
Chevette heatercore
Delta 120mm fan at 7v
PVC 3/8" tubing
The order goes pump>heatercore>cpu block>northbridge block
I think one problem might be that my fan shroud doesn't cover the entire heatercore. I had to cut it so that the fan angles at a 45 degree angle. would that kill airflow? Should I make a modified a shroud so airflow is still straight but the fan is to one side?
I'm running an AMD XP2000+ at stock speed.
Maxijet 1000
Chevette heatercore
PVC 3/8" tubing
