right im try to edit some config files but need root access how do i get it i am the only user
P paxoman Registered Joined Jun 21, 2001 Nov 15, 2002 #1 right im try to edit some config files but need root access how do i get it i am the only user
moorcito Member Joined Sep 19, 2002 Location Chicago, IL Nov 15, 2002 #2 at a prompt type su and then the root password. After you're done editing type exit to go back to normal user.
