- Jul 5, 2003
- Frederick, MD
you don't need it 'cause you have a P4... The shim helps prevent people from cruching their CPU's core if it's an Athlon/Duron/Athlon XP.aTk_H2o said:whats a shim????
As far as extra fluids go... You shouldn't need any as that looks like an all copper kit, so you don't need to worry about anything except baterial growth. That can be fixed with bioside/anti-freeze in small amounts. As far as measuring goes, you can either premix the anri-freeze, use a measuring cup and mix as you go, or just guess.
BTW, if you get the chance, I sugest picking up a heater core. It should help temps a good bit. The popular ones are the '86 Chevette (two pass and 1 120mm fan per side w/ shroud), the Fedco 2-342 (single-pass and 2 120mm fans per side w/shroud), and the 77 bonneville w/ac (two-pass and 2 120mm fans per side with shroud). The fedco-2-342 is the best option IMO if you can fit it in your case...
