- Dec 14, 2004
- Charlotte, NC
I recently purchased a X5660 to replace the 920 in my daily driver. Still using the Gigabyte EX58 Extreme with the most recent BIOS. I was able to reach 225ish BLCK with the 920 but never ran that for daily settings.
My goal with the X5660 is to run 200 blck @ 4600mhz. I revisited the excellent x58 overclocking guides http://www.techpowerup.com/forums/threads/overclocking-the-x58-a-practical-guide.108526/ and http://www.techreaction.net/2010/09/07/3-step-overclocking-guide-bloomfield-and-gulftown/ and followed them pretty well.
Both mention safe limits for QPI-VTT voltage around 1.35v to 1.4v with one mentioning damage when going past 1.35v on 32nm chips.
Problem is, I'm hitting a pretty hard blck wall just over 180. 180 boots and passes stability tests with the 1.35v core, 23x multi (4140mhz), and 1.335v QPI-VTT. 185 isn't stable at 1.4v QPI-VTT and 190+ won't boot at all no matter what voltage.
What am I missing here? Is 1.35v QPI-VTT still recognized as the point where damage occurs? I'm water cooled and temps are in check, can I push it to 1.45v for suicide runs to see if I can even boot at 200blck? Is 1.45v out of the question for 24/7?
I did upgrade to 12gb of ram (6x2gb). I thought that was the problem so I pulled the 3 new sticks and the voltages required and blcks achieved don't change.
