help on new system after Nautilus from corsair crapped out.
toddd240
Denver
My previous wc system developed a leak and crapped out. Temps were originally in the 31c to 36c range and now have shoot up to 43c. I replaced the corsair with a fan and I am getting the same temps. I am now going to take the full plunge and wc everything shortly. It will be a x6800 cpu, 680i chipset and two 8800gtx. Does anyone have any personnal recommendations on the setup. I am specifically looking for the order in the setup of the loop and any specific parts people would recommend. Thanks in advance.
well, how much do you want to spend? all out, or budget?
if you want all out.
Swiftech Storm - apogee for cheaper
Thermochill pa 120.3 with some quiet fans. - mcr320 for cheaper
mcp350 w/ petra's top - d5 for cheaper
1/2 inch tubing tygon - masterkleer
2x eddy's full cover waterblocks. - some mcw60's with the adapters(if im not mistaken you need one) and bunch of ramsinks. and i mean a bunch
