Looks good MM maybe a bit of extra work with those on/off switches but keeps it safe. I'd gle down those solder joints/wires so they can't work loose and break the connection
I hope I'm right on how I did the read points in the Molex connector. I should be able to have a probe in the ground slot and one in another, this should give me real time readings
I like it, as Johan said though add some more glue. I found that I really had to add extra glue around the trimpots and the on/off switches otherwise I kept knocking them off the card.
If Dolk is not available let me know and I might be able to work on one or two for you. My timeframe for completing them might be a little slow if you don't mind waiting.
Hey Shawn how you going good I hope.
If you need extra glue on your solder joints you aint doing it right.
The only place I use glue is to glue the trimpots on if the card gets warm.
