- Dec 27, 2008
Under load, your CPU fan should be turning much faster than that. From post #1 it shows the max speed under load as 981 rpm if my eyes are deceiving me. I think your CPU fan is not turning fast enough to efficiently carry away heat at those low speeds.
Putting in front push fans may help a little but the exhaust fans are much more important.They will pull in fresh air through the front grill.
Have you checked your fan profile settings in bios?
