- Sep 20, 2001
- Minneapolis
Here is my problem. It is not new, I have experienced it, or problems similar to it in nature on different computers. For purposes of the discussion here, I will give the specifics of the system in question.
I have an ECS K7S5A with a cheap SiS 6326 8MB AGP vid card, using Win98SE. I leave it idle for a few hours, and the monitor is dark, like I would expect. I hit a key or move the mouse, and although the monitor comes back on, the mouse is frozen. The screen looks wierd also, kind of scewed to one side. What is causing this? The only remedy is to reboot.
I would note that I have had this problem with other computers as well, with varying degrees of severity. On some, the mouse will appear frozen, but actually only the pointer is frozen, you can move it (while it is invisible) and right click to see that it has in fact moved. Other times, the comp might be completely frozen...
This has happened with a similar SiS 6326 PCI card, as well as with a Radeon. Maybe even others...
Help is appreciated, in any form.
thanks,
flounder43
thanks,
flounder43
