- May 28, 2009
- London
Hi all,
First of all, this is a cool place, and I'm disappointed to not have discovered it earlier! Hello, OCers
I have a really interesting problem on what would be known as an 'ancient relic' of a self-built PC at the moment. The specs are as follows:
- ASUS P4PE Motherboard (not to be mistaken with P4PE-X or P4PE/L etc.) with P4i65G chipset
- Pentium 4 2.53GHz Processor
- 2x Kingston PC2700 1GB RAM (total 2GB)
- Sapphire ATI Radeon x1950 Graphics Card
- Creative Sound Blaster Audigy! Sound Card with Live! Drive
- WD 250GB SATA Hard Drive
- CD-R & DVD-RW
- QTec 550W TruePower Supply
- Coolermaster ATX-210 case
- (WinXP SP3)
Some of you must be thinking, "Bloody hell, he's OLD!". The computer started off with 2x 512MB RAM sticks, a Ti4600 graphics card, an IDE hard drive and a 350W power supply. All have been changed over the years, the most recent one being the upgade to two 1GB sticks of RAM (at a cost of £60, yowzers).
I'm having a really, really weird problem with this system though and I'm hoping someone can help me out. It all started when, sometimes, playing rFactor, I'd get strange lines across the screen or the system would hang up. This would happen perhaps once in every two hours I played.
I then thought the system might simply be (finally) eating too much memory, so thinking RAM was the bottleneck I went and upgraded.
Sadly, the error kept occuring. I then wondered...oh dear, what if the power supply's capacitors were beginning to die out (like my old 350W did when I got the Ti4600 which is why I replaced it)? But then I realised, it's a 550W TruePower supply, which I would think should have enough power to sort out everything in my computer.
I then tried another test. I ran 3DMark06 (my computer originally got 11 points on the thing, haha - now up to a respectable relic level of 2700 last time it worked). However, the computer would hang - AT THE SAME POINT EVERY TIME. Almost at the end of the "Firefly" test, the computer would simply black-screen on me with zero reaction whatsoever (not even black screen, strictly speaking - the monitor would have no signal, I'd still hear humming from fans etc. but everything becomes non-responsive). I've now tested this 4/5 times and it seems to hang at the same place.
I'm now in the process of disconnecting the CD-RW and the DVD-RW from their respective power supplies and running the test again, JUST to see if it's a power supply problem, but I bet it doesn't have anything to do with it at the end of the day.
Can anybody shed some light as to what's going on? I will post updates as and when they become available.
Thanks ina dvance for all your help
Cheers,
WB
- CD-R & DVD-RW
- (WinXP SP3)
Cheers,
WB
