Hi, I just upgraded the memory on this Motherboard from 1Gb (2X 512Mb) DDR PC3200 400Mhz to Patriot Extreme Performance 2Gb (2X 1024Gb) DDR2 PC6400 4-4-4-12 Memory I know that the speed of this memory is twice as fast as the old stuff but I have read and was told when I bought it that it was OK to put faster memory in because it will clock it's self down to the FSB speed. The problem is that I think the processor can't keep up and when running either several programs at once or games my system will Blue screen and shut down. I think I may need to increase or decrease either the speed or voltage on the CPU or the memory. I do not want to make the wrong adjustments and fry something so can you give me an idea what I should do to try and fix this problem?
Here is what my system report looked like before adding the DDR2 memory. By the way this motherboard will take both DDR & DDR2 memory and yes I know the board is crap, but it's what I had laying around from an old system and I can't afford to buy a new board these days because like a lot of Americans these days I lost my job 6 months ago and there's no one hiring.
Thanks for any help you can give me.
Jim O
See report below
Taken from SiSoft Sandra
Model: ECS P4M800PRO-M
Workgroup: MSHOME
Host Name: csi-c35e9b48aae
User: CSI
< Processor >
Model: Intel(R) Pentium(R) D CPU 2.80GHz
Speed: 2.8GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Dual-Core
Integrated Data Cache: 2x 16kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte
line size, 2 lines per sector
< Computer >
Mainboard: ECS P4M800PRO-M
BIOS: American Megatrends Inc. 080012 07/19/2006
Bus(es): ISA X-Bus AGP PCI IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC
Yes
Total Memory: 992MB DDR
< Chipset >
Model: ECS Standard Host Bridge
Front Side Bus Speed: 4x 200MHz (800MHz)
Total Memory: 1GB DDR
Shared Memory: 32MB
Memory Bus Speed: 2x 200MHz (400MHz)
< Memory Module(s) >
Memory Module: Kingston K 512MB DDR PC3200U DDR-200 (3-3-3-8
2-11-0-0)
2-11-0-0)
< Video System >
Video Adapter: VIA/S3G UniChrome Pro IGP (AGP 3.00)
< Storage Devices >
WDC WD1200JD-00GBB0 (120GB, SA:112GB (C
Lexmark USB Mass Storage (USB):N/A (E
HL-DT-STDVD-RAM GSA-H22L (ATA6:N/A (D
MAT****ADVD-ROM SR-8587 (ATA33:N/A (F
< Logical Storage Devices >
Hard Disk (C
: 112GB (NTFS) @ WDC WD1200JD-00GBB0 (120GB,
SATA150, 3.5", 7200rpm, 8MB Cache)
Optical Drive (D
: N/A @ HL-DT-STDVD-RAM GSA-H22L (ATA66, DVD+-
RW, CD-RW, 2MB Cache)
Optical Drive (F
: N/A @ MAT****ADVD-ROM SR-8587 (ATA33, DVD-R,
CD-R, 256kB Cache)
3.5" 1.44MB (A
: N/A
Removable Drive (E
: N/A @ Lexmark USB Mass Storage (USB)
< Peripherals >
LPC Hub Controller 1: ECS VT8237 PCI to ISA Bridge
LPC Legacy Controller 1: ITE IT8718F
Audio Device: ECS K8M800-M2 (V2.0) onboard audio
Audio Codec: Gammagraphx 0000h
Serial Port(s): 1
Parallel Port(s): 1
Disk Controller: ECS VIA SATA RAID Controller
Disk Controller: ECS VT82xxxx EIDE Controller (All VIA
Chipsets)
USB Controller 1: ECS VT82xxxxx UHCI USB 1.1 Controller (All
VIA Chipsets)
USB Controller 2: ECS VT82xxxxx UHCI USB 1.1 Controller (All
VIA Chipsets)
USB Controller 3: ECS VT82xxxxx UHCI USB 1.1 Controller (All
VIA Chipsets)
USB Controller 4: ECS VT82xxxxx UHCI USB 1.1 Controller (All
VIA Chipsets)
USB Controller 5: ECS VT6202/12 USB 2.0 Enhanced Host
Controller
SMBus/i2c Controller 1: VIA VT823x SMBus
< Printers and Faxes >
Printer: Microsoft XPS Document Writer (600x600,
Colour)
Printer: Lexmark 5400 Series (4800x4800, USB, Colour)
Printer: Fax Lexmark 5400 Series Printer (200x200,
Colour)
< Scanners and Cameras >
Scanner: Lexmark Lexmark 5400 Series (Scanner, USB)
< Network Services >
Network Adapter: VIA Compatable Fast Ethernet Adapter - Packet
Scheduler Miniport (Ethernet, 100Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System >
Windows System: Microsoft Windows XP Professional 5.01.2600
(Service Pack 3)
Platform Compliance: x86
< Performance Tips >
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Processor Arithmetic >>>
< Benchmark Results >
Aggregate Arithmetic Performan:11.25GOPS
Dhrystone ALU: 12.3GIPS
Whetstone iSSE3: 10.2GFLOPS
Results Interpretation: Higher index values are better.
< Performance vs. Speed >
Aggregate Arithmetic Performan:4.03MOPS/MHz
Dhrystone ALU: 4.40MIPS/MHz
Whetstone iSSE3: 3.65MFLOPS/MHz
< Performance vs. Power >
Processor(s) Power: 79.97W
Aggregate Arithmetic Performan:140.68MOPS/W
Dhrystone ALU: 153.88MIPS/W
Whetstone iSSE3: 127.47MFLOPS/W
< Performance Test Status >
Result ID: Intel(R) Pentium(R) D CPU 2.80GHz (2C, 2.8GHz,
2x 2MB L2, 800MHz FSB)
NUMA Support: No
SMP (Multi-Processor) Benchmar:Yes
Total Test Threads: 2
Multi-Core Test: Yes
SMT (Multi-Threaded) Benchmark:No
Processor Affinity: P0C0T0 P0C1T0
System Timer: 2.8GHz
Number of Runs: 64000 / 640
< Processor >
URL: http://www.intel.com
Speed: 2.8GHz
Peak Processing Performance (P:11.18GFLOPS
Adjusted Peak Performance (APP:3.35WG
Type: Dual-Core
byte line size
< Features >
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
Supplemental SSE3 Technology: No
SSE4.1 Technology: No
SSE4.2 Technology: No
AVX - Advanced Vector eXtensio:No
FMA - Fused Multiply/Add eXten:No
SSE4A Technology: No
FMA4 - 4 Operands Fused Multip:No
HTT - Hyper-Threading Technolo:No
Notice 5008: To change benchmarks, click Options.
Notice 5004: Synthetic benchmark. May not tally with 'real-
life' performance.
Notice 5006: Only compare the results with ones obtained
using the same version!
tip.
<<< Processor Multi-Media >>>
Aggregate Multi-Media Performa:17.51MPixel/s
Multi-Media Int x8 iSSE2: 21.41MPixel/s
Multi-Media Float x4 iSSE2: 13.61MPixel/s
Multi-Media Double x2 iSSE2: 7.32MPixel/s
Aggregate Multi-Media Performa:6.27kPixels/s/MHz
Multi-Media Int x8 iSSE2: 7.66kPixels/s/MHz
Multi-Media Float x4 iSSE2: 4.87kPixels/s/MHz
Multi-Media Double x2 iSSE2: 2.62kPixels/s/MHz
Aggregate Multi-Media Performa:218.98kPixels/s/W
Multi-Media Int x8 iSSE2: 267.75kPixels/s/W
Multi-Media Float x4 iSSE2: 170.23kPixels/s/W
Multi-Media Double x2 iSSE2: 91.51kPixels/s/W
NUMA Support: No
Rendered Image Size: 1920x1080
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
< Features >
SSE Technology: Yes
life' performance.
tip.
<<< Multi-Core Efficiency >>>
Inter-Core Bandwidth: 663MB/s
Inter-Core Latency: 301ns
Results Interpretation: Lower index values are better.
Inter-Core Bandwidth: 0.24MB/s/MHz
Inter-Core Latency: 0.11ns/MHz
Inter-Core Bandwidth: 8.29MB/s/W
Inter-Core Latency: 3.76ns/W
< Capacity vs Power >
Total Cache Size: 8.25kB/W
< Detailed Benchmark Results >
Processor Affinity: CPU0-CPU1
2x8kB Blocks Bandwidth: 689MB/s
4x8kB Blocks Bandwidth: 646MB/s
2x32kB Blocks Bandwidth: 639MB/s
4x32kB Blocks Bandwidth: 672MB/s
16x8kB Blocks Bandwidth: 660MB/s
2x128kB Blocks Bandwidth: 643MB/s
4x128kB Blocks Bandwidth: 705MB/s
16x32kB Blocks Bandwidth: 667MB/s
64x8kB Blocks Bandwidth: 661MB/s
16x128kB Blocks Bandwidth: 697MB/s
64x32kB Blocks Bandwidth: 690MB/s
64x128kB Blocks Bandwidth: 596MB/s
Buffering Used: No
NUMA Support: No
Page Size: 4kB
Use Large Memory Pages: No
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
life' performance.
Tip 11: Use the 'Switch Chart Type' button to switch
between Detailed and Combined charts.
tip.
<<< Power Management Efficiency >>>
<< ALU Power Performance >>
<< 50i/25Hz (25fps, e.g. interlaced PAL video) >>
ALU Power Performance: 3GIPS
Power Efficiency: 0.00
ALU Power Performance: 1.04MIPS/MHz
ALU Power Performance: 36.50MIPS/W
< APM System Status >
Processor Dynamic Throttle Pol:None
Optimised for Performance: No
NUMA Support: No
SMP (Multi-Processor) Benchmar:No
< Breakdown at 500 MIPS Workload >
Average Clock Ratio: 100% (2.8GHz)
< Breakdown at 1000 MIPS Workload >
< Breakdown at 1500 MIPS Workload >
< Breakdown at 2000 MIPS Workload >
< Breakdown at 2500 MIPS Workload >
< Breakdown at 3000 MIPS Workload >
< Breakdown at 3500 MIPS Workload >
< Breakdown at 4000 MIPS Workload >
< Breakdown at 4500 MIPS Workload >
< Breakdown at 5000 MIPS Workload >
< Breakdown at 6000 MIPS Workload >
< Breakdown at 7000 MIPS Workload >
< Breakdown at 8000 MIPS Workload >
< Breakdown at 9000 MIPS Workload >
< Breakdown at 10000 MIPS Workload >
< Breakdown at 11000 MIPS Workload >
< Breakdown at 12000 MIPS Workload >
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
life' performance.
Tip 1108: Processor power policy not optimal. For best
power management efficiency, choose the
adaptive mode.
tip.
<< 60i/30Hz (29.97fps, e.g. interlaced NTSC video) >>
Jim O
See report below
Workgroup: MSHOME
User: CSI
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
< Computer >
< Chipset >
Shared Memory: 32MB
2-11-0-0)
2-11-0-0)
< Video System >
< Storage Devices >
Hard Disk (C
Optical Drive (D
Optical Drive (F
CD-R, 256kB Cache)
3.5" 1.44MB (A
Removable Drive (E
< Peripherals >
Serial Port(s): 1
Parallel Port(s): 1
Chipsets)
VIA Chipsets)
VIA Chipsets)
VIA Chipsets)
VIA Chipsets)
Controller
Colour)
Colour)
(Service Pack 3)
tip.
NUMA Support: No
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
< Features >
SSE Technology: Yes
life' performance.
tip.
NUMA Support: No
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
< Features >
SSE Technology: Yes
life' performance.
tip.
Buffering Used: No
NUMA Support: No
Page Size: 4kB
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
life' performance.
tip.
NUMA Support: No
< Processor >
Speed: 2.8GHz
Type: Dual-Core
byte line size
life' performance.
adaptive mode.
tip.
