Help! Strange memory OC issue.
Nahrix
BC, Canada
I posted this in the DFI board as well, since the OC is on a DFI mobo.
When leaving the FSB at default (200), and the RAM ratio at 1:1, I see the RAM at 400mhz at POST, and 200mhz in CPUz.
When the FSB is 200, ratio at 7:6, it POSTs displaying 466mhz, but 136mhz in CPUz!
What's going on?
Where does it post 466MHz? In Memtest?
If yes then that's nothing strange cause Memtest can't recognize some dividers and in that case it refers to 1:1 or higher.
You should also consider updating your BIOS.
