Dear TRend How are you hop all is well
Sorry for the late reply i was very very Busy today at work normally i should be able to check back with you but if i dont this means i am tied-up some where , and please dont forget the time difference between us
So last Night i did a few searches on google about the Blue screen physical memory dump 90% of the feed back that i got was corrupted drives , and this is very similar to my situation. I have reasuntly Bought a usb 3.0 PCIe and a 4 port usb 2.0 , For some add reason my computer wont recognize them although i have downloaded the drivers from the website , If i think clearly i would say i never had this Blue screen in the past but this has been going on ever since i installed the USB 3.0 PCIe .
Not yes i have disabled ACC
I am trying to remember your Questions Oh yes no i never get a blue screen during Prime95 never
My assumption and this is only me talking ( the Newbi )
anything above 3.91 it looks like the PC freezes or i should say it looks like if you are playing a Game and your video card is dragging I hop i have explained this in the right way
this happens when i open Opera and opera loads 4 or 5 taps i noticed it more this way , But 3.91 and below never get the blue screen and pc runs smooth.
I would also like to mention to you that i have Acronis always running in the Background i am using this nonstop back up maybe this is it not sure as i said this is only me talking ..
So here is what i would Like to do today since i am off work now
I will take both the usb 3.0 and the usb 2.0 hardware out , Put the CPu/HT back to 243 and run a prime teast for 1 hour and see how this goes , then i will update you on the results asap when prime is don ..
The other thing that i keep thinking about is the Blue screen keeps saying memory dump so My dear friend can it be the memory over voltage ??? should i rains it a little bit more ????
Because i have ran the memteast86 and my memory is super .
So this is where i stand right now I hop i covered as much as possible and please forgive me , you have mentioned sometimes it is hard for you to understand me English is my second Language
talk to u in a Little Bit
