Help Updating Bios
1Time
U.S. East Coast
I have the new bios is in a zip file. Do I save this zipped file to a floppy disk or save the unzipped contents?
Here is a link to the Asus instructions, which doesn't make it clear to me which to do.
Thanks
1Time
1Time
U.S. East Coast
Sure, that's what I would do - without reading the instructions.
But check out that ASUS link. Step 3 states, "Please insert unzipped BIOS..."
1Time
1Time
U.S. East Coast
OK, sorry, I was confused. So I put the unzipped bios on the floppy. Thanks
Next question:
How do I format the floppy with Win XP ?
The options in Win XP are "quick format" and "MS DOS bootable".
Seems to me the disk would not need to be bootable since I will be using the EZ Flash utility that's in the current bios.
Does this seem correct? Or, do I need the disk to be bootable?
1Time
1Time
U.S. East Coast
and do not flash with in window use ezflash in bios you can use a flash drive if the bios is to big for the floppy
Rich
No intentions of flashing with Windows. Plan on using EZ Flash in bios. But I had no idea the bios could be bigger than the floppy.
How to format the floppy? Quick or bootable?
1Time
1Time
U.S. East Coast
It doesn't need to be bootable
Can I get a vote by anyone else to form a consensus?
That's makes sense to me. Thanks. The EZ Flash program is accessed through the current bios menu after pushing DEL soon after start up.
So only the unzipped bios is needed on a normally formatted floppy - right?
1Time
1Time
U.S. East Coast
Right again, Alt+F2 in EZ Flash. I found the manual online, and it's fairly clear that a bootable floppy is not needed.
Thanks.
1Time
1Time
U.S. East Coast
Got a warning message in EZ Flash - something like "size of bios file does not match current bios file". Do I disregard and proceed?
I tried bios 1502 first, size 512kb. Bios 1801 is 1mb. Don't know the size of the original bios 1403.
Trap05
How is asking what board you're trying to flash off topic? You're here for help and I was trying to offer it
Trap05
So not answering my question so I can look up your board and double check things for you speeds things up?
1Time
1Time
U.S. East Coast
I flashed the bios with EZ Flash. The flash went OK, but the bios may have killed the board. I'm addressing this in another thread. I probably should have cooperated with your request and been more patient. Perhaps I could have avoided the issues I'm now dealing with. I was under a short deadline, which just got extended. Thanks again for your help.
