- Apr 12, 2001
- Kansas City
Just downloaded and ran MBM last night. Gawd. What a shock...
My mobo temp (Abit BM6-socket 370) showing 45C while my CPU temp (Celery 400 not-o/c'ed, with Intel boxed hsf) showing 50C.
This is my case drawing. It is similar to YCC-801 case, although it is not it... (this one comes with plastic slider for drives, no screw)
[img="[URL]http://www.geocities.com/maxis95/Case.gif[/URL]"]
Cool drawing huh?
Anyway here's some notes:
The little blue dot is the thermistors. The 40mm (or issit 30mm?) fan on the back is not installed (it's available). The 80mm fan in front has some air blockage issue (the case will be drilled to open more soon). There is one empty 5.25 bay that I can slid in a bay cooler if needed be. The back and side (not shown) aeration holes are covered with tape (someone suggested that). All cables and stuff are stuffed neatly (no round cables though).
Any suggestion as to reduce the temp inside my case?
Should I:
a. buy that 40mm fan and install it to flow out (or in?)
b. buy bay cooler? issit worthed?
c. change the 80mm to something larger? (don't know if I can or not... forgot to measure the case)
d. others?
I am also awaiting my Celery 566 w/ Intel boxed hsf (yes, again), thinking about o/c-ing it to 700 or more. I am also buying AS2 and plan to use it with the Celery 566. Do you think I should buy Alpha PEP66T and install it before I o/c'ed that CPU?
Thank you for your help! Really...
Cool drawing huh?
Should I:
d. others?
