hello everyone, I installed a watercooled setup into my Shuttle miniPC. My mobo has a built in feature that powers down the computer if the CPU temp reaches 85C and turns on a red overheat light. Well.....when I try to power the system up, it comes on for one second and then powers down and lights the up the overheat led.
Here is my WC Setup:
Tygon Tubing
(3/8 ID 1/2 OD)
Swiftech MCW-5000A
(its seated firmly with AS3)
DangerDen Radeon GPU Block
(seat firmly with AS3)
this pump
this radiator
(with 2 Vantec Stealth fans pulling air through it)
Any Ideas why my CPU would be getting this hot?
Tygon Tubing
(3/8 ID 1/2 OD)
Swiftech MCW-5000A
this pump
this radiator
