Sicco1:
A BIOS update maybe of help. I flash my BIOS at each new version since v1001A and its safe. Go to the ASUS web site, find the latest BIOS of your mobo and the flasher, follow the instructions and you're done!
Here are my SANDRA2001te results. VCore is set at 1.75V (default):
..... ..... ..... ..... ..... ........... ...... CPU ...... .. Multimedia ... .... Memory .....
.FSB. SDRAM .PCI. .CPU. .RAM. ..Timings.. ..ALU... ..FPU... ..INT... ..FLOAT. ..ALU... ..FPU...
(MHz) (MHz) (MHz) (MHz) .(MB) ..(cycles). .(Mips). (Mflops) .(it/s). .(it/s). .(MB/s). .(MB/s).
.133. .133. ..33. .800. .512. .2-2-2-5/7. ..2167.. ..1090.. ..4394.. ..5375.. ...352.. ...392..
.150. .150. ..37. .900. .512. .2-2-2-5/7. ..2420.. ..1216.. ..4906.. ..6002.. ...356.. ...388..
.160. .160. ..40. .960. .512. .3-2-2-5/7. ..2583.. ..1293.. ..5236.. ..6406.. ...374.. ...414..
.166. .166. ..42. 1000. .256. .3-3-3-5/7. ..2690.. ..1346.. ..5454.. ..6673.. ...343.. ...372..
.166. .166. ..42. 1000. .256. .3-2-2-5/7. ..2714.. ..1346.. ..5454.. ..6673.. ...397.. ...439.. (*)
.170. .128. ..43. 1.02. .512. .2-2-2-5/7. ..2770.. ..1373.. ..5566.. ..6811.. ...321.. ...339..
.172. .129. ..43. 1.03. .512. .2-2-2-5/7. ..2803.. ..1390.. ..5634.. ..6893.. ...321.. ...331..
.200. .150. ..50. 1.20. .512. .2-2-2-5/7. ..3236.. ..1622.. ..6561.. ..8027.. ...390.. ...423..
The last line was obtained with my previous configuration (HD Maxtor DiamondMax Plus 60, 60.5 GB, 7.200 rpm and no audio card). I believe I can reach these frequencies with my IBM 60GXP and no SB Audigy, as well. If the audio card is installed I can't get a stable system if PCI is greater than 43 MHz.
I can't see great increases in the scores with 2x 256 MB RAM. I wonder, if I have a graphics card, the results would be greater...
In time, the correct option in the [Advanced > Chip Configuration] section is:
SDRAM Data Driving Mode : Strong
That will marginally increase the power to your DRAM banks.
[]'s
ASUS CUSL2 (i815E) (using onboard VGA)
Pentium III (SL52P cD0) 800EB @ 1.0 GHz (FSB/SDRAM/PCI = 166/166/42 MHz)
2 x 256MB Crucial PC133 SDRAM (CL=2) (only one in use)
IBM DeskStar 60GXP 60 GB
SB Audigy MP3+
Lucent Winmodem 56K
HP CD-Writer 9300 Plus
Sony DVD 1211-82 (12x)
Windows 2000 Professional
Red Hat Linux 7.1
