I thought you should have it enabled.
If I disable it now should I reinstall Win2K?
Thanks for the quick answer.
The pic looks bad because I just finished reinstalling the OS.
I have been having file corruption errors on this WD1200JB drive.
I downloaded the Western Digital diagnostic disk. It ran for an hour and no errors.
It is an Epox 8K3A+ with an unlocked AROIA xp1600.
I had the WD1200JB behind the highpoint at first. After my first error I moved it to the on board IDE channel.
Someone told me the IDE channels were connected through the V-Link bus and not the PCI bus, I am hoping to avoid the PCI bus problem.
thank you for your quick help.
Right now I am running chkdsk on the drive, it is taking a lifetime.
How do I make sure that the OS is using UDMA100?
I also have a DVD drive that only takes UDMA33.
I put it on with the hard drive because I wanted my burner to have a dedicated channel. The only time I use the DVD is when hard drive performance won't matter. Burning cd to cd or playing a DVD.
thanks again
