- Feb 25, 2004
- N of splat W of Torin
Need some help adding a 2nd RTX 2060 to the Windows 7 rig in my sig...
First: the MSI Mobo is older, it needed an update to the BIOS to run the RTX 2060 in the 0 slot (Top) It worked fine after that.
Second I have had 2 GPU's folding recently, an GTX 970 in the 0 (Top slot) amd the RTX 2060 in the 2nd slot (1) (No BIOS update was needed at that time)
Third: The GPU's 2 EVGA RTX's Show up in windows and are using a recent driver 442's or there abouts.
Fourth: I finished the work I was doing, uninstalled the V7 client added the 2nd GPU and tho its seen in windows, the client doesn't see it.
Fifth : I reinstalled (The V7 client)and restarted Windows 3 times, trying to get it to recognize the 2nd GPU (No luck)
So I have found it impossible to manually install a 2nd slot for a GPU it only add's a CPU slot (A real PITA), so I always uninstall reinstall the client...The problem with this is you can not keep it from instantly running. So rather than lose any more WU's ....Hoping someone could help with this. I have done this a few times before and its been successful...at a loss now.
I am hoping the issue is not with the MOBO.
Has anyone ever had success adding a GPU client manually? Maybe I am doing it wrong.
EDIT: I switched to the 2nd GPU for the HDMI out..didn't help. Also MSI Afterburner see's the GPU, which makes me think its the V7 Client.
EDIT: Today(01-18-20 I'll try...
Switching the new EVGA RTX KO Ultra 2060 with another RTX 2060 from my main PC...Maybe the new KO is the issue...The 2 GPU's will be exactly the same.
Install Windows 10, see if it makes any difference. I'll report back...Not sure if I am up to installing Ubuntu and spending the time getting 2 GPU's to fold.
Also the 2 GPU's both show up in the V7 system log.
