UMMM... I am truly sorry, but there is a misconception of sorts here. Repo, I do understand most of what you are talking about. IF what Klownin is trying to do is flash his system board bios, you know, the main bios for all the motherboard functions, he does not need a special NTFS or NT bootdisc. ALL YOU NEED IS A FORMATTED SYSTEM DISC FROM ANY WIN9X MACHINE. THEN COPY THE AWARD FLASH UTILITY ONTO THAT DISC AND ALSO THE .BIN FILE YOU WANT TO FLASH WITH. ONCE YOU HAVE THAT ON THE DISC, PUT THE DISC INTO THE FLOPPY DRIVE AND REBOOT. UPON REBOOT, YOU SHOULD BE BOOTING FROM THE FLOPPY DRIVE AND IT SHOULD SAY, STARTING WIN9X, AND THEN YOU WILL END AT THIS
A:\
ONCE YOU ARE HERE, TYPE IN AWDFLASH
THE AWARD FLASH PROGRAM WILL START AND THEN JUST FOLLOW DIRECTIONS.
I am not trying to flame anyone or get you upset, but this is how it works. I am running xp pro, and I just got done putting the system disc I made from win98se in and rebooted and I was able to start the flash program no problem.
If Klownin is NOT trying to flash the mainboard bios, but something else then Repo seems to really know his stuff and I am full of crap, but if you are doing the mainboard bios, IT DOES NOT MATTER WHAT OS YOU ARE USING, BECAUSE BOOTING FROM A FLOPPY COMES BEFORE YOUR HARDDRIVE, AND IT DOES WORK.
Sorry again.
Later.
