- Feb 12, 2001
- Fayetteville, AR
Well my dad has 3-30 gallon tanks of n2. And i was wondering if i went to a watercooling setup if i could mix in say a liter of N2 to make the water really cold? What i also wana know is would N2 freeze the lines/pump/radiator. IF so than how is N2 applied? Also how long before it evaporates in the open air. If i run an inline pump from the tank to the water/n2 block on the cpu and then back into the tank will that work? Id like to use a couple gallons of just N2 but have never used water or n2 before-help needed on the applicatin please
