Ok . Here are my system specs first:
1.2 ghz Tbird @ 1350mhz (10x135mhz)
Abit KT7A Raid Motherboard
Hercules Geforce 2 Ultra
256megs PC150 TinyBGA
Ibm 61.4 gig hd
SB Live Platinum 5.1
Plextor 16x10x40
Pioneer 16x DVD
for cooling i have a max cool case average temp for system is 23 degrees celcius .. for the cpu i have an alpha pep66 with the black label delta fan and artic silver 2 thermal paste .. my cpu temp is 39 celcius at idle .. what can i do to cool this .. is this an ok temp ?? for idle ?? its says in the via hardware monitor that 40 is cpu hysteresis and 50 is overheat ?? i tried running at 10 x 140 temp still the same ..
any ideas to help cool .. i would think with this cooling i should have good temps ??
please advise .. thanks
Ibm 61.4 gig hd
Plextor 16x10x40
Pioneer 16x DVD
