- Apr 23, 2001
2 Questions for all you air cooling experts...
Case is a Inwin Q500N. I have 4 fans installed already: 80mm Panaflow in front (intake), 2 80mm Panaflows in the rear (exhaust, stock locations). I have a slot cooler below the video card (exhaust).
I placed a Panaflow 120*120*38mm fan into a cut hole in the side panel for intake. The hole is just below and to the right of the processor's HSF (60mm Delta 38CFM). All fans at 12V. The case fans are quieter than the Delta. Noise isn't an issue
My estimated intake CFM is ~140
My estimated exhaust CFM is ~80-90 (including Power Supply)
I've seem to have quite a bit of back pressure with the 120mm. (too much positive pressure?)
Case temp didn't drop more than 4 deg. celcius than before 120 was installed. Trying to achieve 3-5 deg above ambient room temps.
Question (1) What's the next step to reduce case temp? (Relocating the 120 is out of question)
Question (2) If were to install another 120mm fan for exhaust, where should it go? Top of case or back of case above power supply. (enlarging the stock 80mm fan location to fit a 120, thus loosing one 80mm fan, but gaining 80 CFM)
Thanks in advance, any help here would be appreciated.
