- Jan 9, 2006
- San Diego, CA
Fisrt off, hi everyone! I'm new to the boards.
Ok so I have a Intel Pentium 4 3.0E Prescott 800MHz FSB 1MB L2 Cache Socket 478 CPU and it runs ridiculously hot. It's running 55 degrees Celcius right now and I only have a few basic programs running (Firefox, Xfire, etc..). With gaming load it reaches insane temps. I need to replace this stock heatsink before I burn out the cpu or something. Plus my room is a sauna because of it.
Normally I would just buy some behemoth heatsink and call it a day, but I have a Thermaltake SViking case which is pretty compact, so size matters.
Can you guys help me find a good heatsink for my setup?
Specs:
Case: Thermaltake SViking VA4000BWS (Demensions 17.4" x 7.9" x 19.9"(HxWxD))
CPU: Intel Pentium 4 3.0E Prescott 800MHz FSB 1MB L2 Cache Socket 478 w/stock heatsink which I would say is a bit less than 9cm high x 9cm wide
Mobo: Intel D865PERL Socket 478 Motherboard, 800FSB, DDR400, AGP8X (12 inches x 9.6 inches)
Ram: 1 gig (2x512) Kingston ddr-sdram
Graphics: XFX nVidia 6800 128mb @ 8x AGP
Power Supply: ATRIX PSCI-500BLK ATX12V 500W (about 9.5 cm high and 16 cm wide/deep)
I think thats about all you need to know... I think the power supply would be the biggest size issue as its already like less than 2cm away from the current heatsink/fan. I'd say the biggest heatsink/fan I could fit in there would have to be 11cm high or less. Small is good but I need something that works really well since my CPU could melt a hole in a bank vault. I'll take a pic tomorrow and add it to this post.
Any help is very much appreciated!
Specs:
