help with kk266r i/o voltage jumper
mark23
the manual says there is 3 pins but mine has six,ive tried varios ways of shorting them to increase the voltage but the voltage still reads the default 3.4 in the bios and with via hardware monitor,can anyone figure out how to use the jumpers?
Im hoping increasing the i/o voltage will improve stability with my axia y 1ghz at 1400mhz.
your jumpers should look like this : : : does it? just connect it like this with a jumper : | : now what does the bios read?
thanks for the help but i just found out that that is not the actual jumper,its actually in a different place from what the manual shows,its to the top right if the dimms,i set it and all is well.
thanks anyway.
did you go for 5% or 10%? I think the iwill manual has about 600 mistakes so check out the fullon3d iwill kk266 faq in my sig just click on the kk266 and you will magically go there. peace
