I'm reporting my OC experience because i'm trying to understand. Hope you can help me out
Very short story, easiest OC experience of my life:
change the multiplier in BIOS and you're ready to go.
Well, ready to go till 3.75GHz that's what makes me mad. The automatic settings are ok but the Vcore is not pushed beyond 1.2V, i can only fine tune with LLC modes 1-8 which gives a subtle offset of max 0.016 in mode1.
I leave AMD Quite'n'cool Active so i get full advantage of p-states in windows and that's the part i love the most.
Problem's that as soon as I set manual Vcore to 1.385 to achieve stable 4GHz (PRIME95 blend test words, not mine xD) I lose p-states functionality as I read it's supposed to be. Well, the multiplier will still change, accordingly to cpu load(thanks to cool'n'quiet), but the Vcore is locked at 1.385 +/- the 0.016 dynamic offset given by the LLC mode 1 I'm finding myself good with.
I'd love to keep p-states functionality ofc and I don't understand if I can do anything to let the automatic settings in the BIOS get beyond 1.2.
You will understand this is just an Overclocker question since i'm going for stable [email protected] out of the box for daily use.
*EDIT RAMS are running @3200 14-14-14 with automatic XMP profile
