- Jan 18, 2016
- Franklin, TN
I've hooked everything up the way the manuals instruct and when I hit the power button it trips the power supply breaker, then takes a few minutes to reset. I have two 6 pin connectors plugged into my graphics card, the 24 pin connector at the motherboard plus one 6 pin going to the motherboard as well, then the powers going to the HDD and cd drive. Power supply is an evga 1000g1. Idk what I'm missing.
SOLVED... I hooked up CPU power incorrectly but got it figured out.
