RSDXzec
Disabled
- Nov 7, 2008
- Queensland, Australia
(QDR = FSB x 4, quad data rate)
ok, i took some statistics of how much voltage i need on my 1.325V VID Q6600 needs at different OC's, i hope someone could tell me if my QDR wall is caused by my CPU or motherboard or RAM.
This is what i think is my problem (in order of chance of being my problem)
1. - CPU - i think is the problem
2. - Mobo
3. - RAM - ive almost taken out my 800mhz RAM as being a problem by reducing the ram speed and ocing unlinked to isolate the CPU
Anyway, here are my OC stats, i hope someone can help
2.4Ghz - stock
Max Temp - 58C
Vcore - 1.29V
FSB - 1.2V
SPP - 1.3V
MCP - 1.5V
HT Link (i think its the same as SPP>MCP, correct me if im wrong) - 1.2V
Oc @ 2.6Ghz
Max Temp 58C
Vcore - 1.325V
FSB - 1.2V
SPP - 1.3V
MCP - 1.5V
HT Link - 1.2V
OC @ 2.8Ghz
Max Temp 61C
Vcore - 1.34V
FSB - 1.2V
SPP - 1.3V
MCP - 1.55V
HT - 1.2V
OC @ 3Ghz
Max Temp - 61C
Vcore - 1.39V
FSB - 1.3V
SPP - 1.3V
MCP - 1.55V
HT - 1.2V
OC @ 3.2Ghz
Max Temp - 63C
Vcore - 1.43V
FSB - 1.3V
SPP - 1.35V
MCP - 1.55V
HT - 1.2V
OC@ 3.4Ghz
Max Temp - 65C
VCore - 1.49V
FSB - 1.4V
SPP - 1.35V
MCP - 1.55V
HT - 1.25V
I cant reach any higher than 3.42Ghz because i keep hitting a QDR wall of 1520
Ive tried putting my Vcore voltage up to 1.6V with the rest on the highest green settings in bios to try to reach 3.6Ghz but i cant, whenever i put my QDR higher than 1520, the PC boots up in safe mode, and tells me that i have to reset the FSB frequency
hope someone can help, thanks
(and this is a copy of my previous post that i had at the end of my own thread but i think its too hidden there, so i posted this thread.
And i know a few of you will think not again, if you have read some t=of my previous threads but id really like to find out why im getting a QDR wall.
2. - Mobo
2.4Ghz - stock
Max Temp - 58C
Vcore - 1.29V
FSB - 1.2V
SPP - 1.3V
MCP - 1.5V
Oc @ 2.6Ghz
Max Temp 58C
Vcore - 1.325V
FSB - 1.2V
SPP - 1.3V
MCP - 1.5V
HT Link - 1.2V
OC @ 2.8Ghz
Max Temp 61C
Vcore - 1.34V
FSB - 1.2V
SPP - 1.3V
MCP - 1.55V
HT - 1.2V
OC @ 3Ghz
Max Temp - 61C
Vcore - 1.39V
FSB - 1.3V
SPP - 1.3V
MCP - 1.55V
HT - 1.2V
OC @ 3.2Ghz
Max Temp - 63C
Vcore - 1.43V
FSB - 1.3V
SPP - 1.35V
MCP - 1.55V
HT - 1.2V
OC@ 3.4Ghz
Max Temp - 65C
VCore - 1.49V
FSB - 1.4V
SPP - 1.35V
MCP - 1.55V
HT - 1.25V
