- Thread Starter
- #21
I went to 1.45 because I didn't know how close i was to passing and i saw a lot of people had to go to almost 1.45 to get to 4.6 stable
and also i wanted to keep trying to go to the top voltage id feel comfortable with using and go down from there. But after a couple tests at 4500mhz bringing down the voltage to bring down the high temps i brought it down to 1.43125 and brought the NB and Ht Link down to 2200mhz and I'm still stable running prime after 2 hours and a half at 61* socket 60 - 62* package with a max of 62 socket and 64 package so I'd say that's pretty decent right? Think I'll drop the voltage down one more step as to try to not get a max of more than 62* and see if its still stable. Or maybe i should drop down the NB and the HT Link back to 2000? or Auto? Not really sure what to do. I'll probably try both.
Okay thanks that's good to know.
These are lucky numbers for a 4100 series. Got a guy at another forum who's loosing worker #3 and running 1.4250v and testing 1.4500v at 4000mhz. His temps are only 51c after 20 minutes of Prime95 blend. His package temp only reached 40c....
So if your seeing only 1.45v at 4.6ghz and actually for real for real stable, then those chips are golden IMO. After having 3 of these chips I also know for a fact 5ghz stable is a golden chip as well. Try 4.8ghz - 4.9ghz best case scenario running in excess of 1.5v in most cases.
Bring the temps down so the voltage can go up.
EDIT
(Just in case no one gets it, I'm saying this is a sweet chip. Push it harder.)
Overstock it looks good and this is about as high as you'll want to go for a 24/7 oc, at least on this cooling. If you want to push higher and see if it passes a benchmark or two you can do so but watch the temps. Additionally, if you look at your ram timings you're running them loose you may want to manually set them to the Xmp 1600 profile in the SPd tab and re test prime to see if it passes with the tighter timings.
Lowering temps at this point would be removing the air cooler and slapping on a water block. You'd appreciate it mostly when you get a couple hundred extra mhz for daily use and likely benchmark at 5ghz good for validation ect.
Looks like your maxed out without adding more cpu v-core.
