- Jul 24, 2004
hi all.
after im getting the VGA silencer to oc my 9800pro
im thinking of doing some basic overclocking to my p-4 2.4C.
what im planing is to overclock my p-4 2.4C cpu by finding the max speed using the PRIME95 proggy without volt modding then i will run sys at about 10% lower just for safty , once i will feel sys is stable i may consider some voltmodding,
i won't start playing with it before i get some proper heat sink + fan (no water cooling pls) , was thinking of the thermallight sp-4
http://www.newegg.com/app/viewProdu...-109-012&depa=0
also what fan should i use with the heatsink 92mm , 80mm? too much noise is a problem for me.
what do you think? there are so many cpu cooloers out there im a little lost.
TIA ,ledzep.
TIA ,ledzep.
