blackirishmec
- May 26, 2021
Hi all! I am building a machine which will have a GPU AIO and a CPU AIO integrated with each other (Alphacool's Eisbaer and Eiswolf connected together).
My Machine Components:
I am considering two different single loop radiator+fan configurations.
Configuration A:
1. 420mm Rad as Front Intake
2. 360mm Rad as Top Exhaust
3. 140mm Fan as Rear Exhaust (PH-F140SK_DRGB_PWM)
Configuration B:
1. 280mm Rad as Front Intake
2. 140mm Fan as Front Intake (PH-F140SK_DRGB_PWM)
3. 360mm Rad as Top Exhaust
4. 140mm Fan as Rear Exhaust (PH-F140SK_DRGB_PWM)
Here is a link to a spreadsheet I've put together with information on the fans used in both of these configurations. Here are some important notes for understanding what I'm doing in the sheet:
• The first tab includes both configurations laid out incl. preset fan max values to try and strive for overall positive pressure in both configurations (seen in the summary rows in sheet 1, column F).
• I have made a pie-in-the-sky "Radiator Resistance" value (column D) to try and guess at the airflow restrictions innate to a fan mounted to a radiator. I wanted to be conservative with this value so I make sure I'm getting positive pressure (for dust management).
• I have included column E to indicate my use of PWM % values on each of the fans involved in the system. While I will not by ANY means be locking the fans to the corresponding PWM % listed in column E, I'm considering building fan curves with the relative ratio of the values in Column E as a method of managing air flow relative to the other fans. So to say it a different way, a Column E value of less than 100% indicates PWM % relative to the PWM % of any fans with a Column E value of 100% in each configuration. That one's a doozy, sorry about that.
My first thought is go for configuration A because more Rad will be ideal for my loop. My second guessing (and preference for configuration B) comes from wanting to manage the heat of non-loop integrated components incl. the GPU backplate, the RAM, and the M.2 SSD's.
It seems that with Summary values in Column F nearly equal and indicating positive pressure (~+5.13 CFM), then:
Case | Phanteks p500a DRGB |
MOBA | MSI MEG z490 Unify |
CPU | Intel 10700kf |
SSD 1 | Samsung 970 Evo Plus 1TB M.2 NVME |
SSD 2 | Samsung 970 Evo Plus 1TB M.2 NVME |
RAM 1 | G.Skill Trident Z RGB 8GB DDR4-4000 CL18 |
RAM 2 | G.Skill Trident Z RGB 8GB DDR4-4000 CL18 |
RAM 3 | G.Skill Trident Z RGB 8GB DDR4-4000 CL18 |
RAM 4 | G.Skill Trident Z RGB 8GB DDR4-4000 CL18 |
GPU | Zotac 3090 Trinity OC |
PSU | NZXT E850 |
Configuration A:
Configuration B:
Metric | Col F: SUM Air Flow Rate (CFM) | Col G: SUM Intake Air Flow Rate (CFM) | Col H: SUM Absolute Loop Fan Air Flow Rate (CFM) | Col I: SUM Absolute Value Loop Fan Static Pressure (mm H20) | Col J: AVG Noise (db (A)) |
Same | 25.50% Worse | 0.69% Better | 2.08% Worse | 0.89% Worse |
