help with setting up sli
Johno4566
hi i got two gtx 285 overclocked ition card i want to put them in sli i but them both in and put the drivers on and the bridge it detects the card are thier and show both card temps
but the sli bit is not showing up to enable it
The lastest driver s are installed
can any out thier help me get this sli to go
as i have never setup sli before
and i did put both of the the 16x pci express slots
i know both card work fine
specs are
i dont know what i did now they are workign in sli mode
i turned nview ona nd it seems to work
i7 920
4GB ddr3 ram
mb Ga-x58A-UD7
Enermax Revolution85+ SLI 1050W
so i got got enough power
os wiindows xp sp3
dejo
Senior Moment Senior Member
do you have the sli bridge installed, wont show up without that
jgv115
Australia
You have to go into the nvidia control panel (i think) to enable. I don't think windows will pop up with a message.
dejo
the first time you boot windows should show the sli capable system, after that not sure. also if you have the win7 wdm drivers they dont seem to be capable of sli, so if you updated through windows than go to guru3d and download, 191.07 as they seem the most stable for me the newer ones seem to have major issues
