M
Me
Guest
Ok i just bought this card and i need some help
I have 2 speakers that sit on the floor hooked up to my sony amp. One is to the left and the other is to the right of me but not in front of me i.e next to the monitor. My question is where do i plug in the cord to the speakers. There are so many colors located on the back of the card im not quite sure which one is the right one. I have a feeling it is the black one but im not sure. Also if i were to get 2 more speakers and say put them beside the monitor would it go in the green hole on the sound card ? Also how do you achieve 5.1??? Do you have to own a dolby 5.1 AMP&receiver? Another question i have is that my floor speakers are big! They are 3-way technics speakers and they have 1 10inch sub and then it goes i think 4inch then 2inch on both sides of me. I need some good advice on how to hook this thing up .
please try to answer all my questions
thanks
thanks
