- Jan 12, 2015
I'm posting a big question on this as I have some understanding but not all
1) How do I know what the SS unit's heat load is?? 200w, 350w all I have is my benching computer for tasting. i7-8700k (de-lidded/direct die no IHS) EVGA z390 Dark MB (max on board CPU temp is 0c - 100c)
2) Does the Cap tube length or Does the Size of the Condenser = how much a heat load it can handle?
3) I have benched my i7-8700k and have observed the following... The Max Cold -35c, Idle -32c, Load -25c (Load was 2 Min of 1080p/4k HWBot x.265 @5.1GHz AVX) The CPU reached a Max temp of +35c.
I do not know if I need to have it re-gassed, this is normal, you are going to damage the compressor because of xxx.
I have included pictures of my SS unit and a basic diagram of how a SS works.
I have thought on taking it to my local HVAC but do not want to be told - Your problem is that when the Liquid (R-134a) turns into gas @ the Evaporator it now has 1.21 Jiggawatts and you need a Flux Capacitor @ the Condenser to return it back to a liquid - OR Your Compressor is only a 1/3, 1/4, 1/2 HP and you need a 1, 2, 4 HP rated one to run/make/cool properly.
Thank You For Your Time
