Help with underclocking memory
netwerkjim
Hi and thank for your help, I just upgraded the memory on this Motherboard from 1Gb (2X 512Mb) DDR PC3200 400Mhz to Patriot Extreme Performance 2Gb (2X 1024Gb) DDR2 PC6400 4-4-4-12 Memory I know that the speed of this memory is twice as fast as the old stuff but I have read and was told when I bought it that it was OK to put faster memory in because it will clock it's self down to the FSB speed. The problem is that I think the processor can't keep up and when running either several programs at once or games my system will Blue screen and shut down.
I think I may need to increase or decrease either the speed or voltage on the CPU or the memory. I do not want to make the wrong adjustments and fry something so can you give me an idea what I should do to try and fix this problem?
I know this is crappy Motherboard but it’s free and the best I can do for now since I lost my job six months ago.
Thanks,
Jim O
SiSoftware Sandra
Computer
Manufacturer : ECS
Model : P4M800PRO-M
Family : To Be Filled By O.E.M.
Version : 1.0
Serial Number : 00000000
SKU Number : To Be Filled By O.E.M.
Computer Chassis
Manufacturer : ECS
Type : Desktop
Can be locked : No
Version : 1.0
Power Cord(s) : 1
Asset Tag : 0123ABC
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : ECS
Multi-Processor (MP) Support : No
MPS Version : 1.40
Model : P4M800PRO-M
Type : Mainboard
Version : 1.0
Asset Tag : To Be Filled By O.E.M.
Location in Chassis : To Be Filled By O.E.M.
BIOS : 63-0100-001131-00101111-071906-P4M800
Mainboard Properties
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
To Be Filled By O.E.M. : Video Adapter (Enabled)
Computer Memory Controller
Error Correction Capability : None
Number of Memory Slots : 2
Maximum Installable Memory : 4GB
BANK0 - DIMM0 : Manufacturer0 PartNum0 SerNum0 AssetTagNum0 DIMM Synchronous SDRAM 1GB/64
BANK1 - DIMM1 : Manufacturer1 PartNum1 SerNum1 AssetTagNum1 DIMM Synchronous SDRAM 1GB/64
Chipset
Model : ECS Standard Host Bridge
URL : http://www.ecs.com.tw/
OEM Device Name : VIA Standard Host Bridge
Revision : A1
Bus : Intel AGTL+
Front Side Bus Speed : 4x 200MHz (800MHz)
Maximum FSB Speed : 4x 200MHz (800MHz)
Width : 64-bit
I/O Queue Depth : 12 request(s)
Priority Master Queue Depth : 4 request(s)
Maximum Bus Bandwidth : 6.25GB/s
Maximum Power : 3.60W
Chipset 1 Hub Interface
Type : V-Link
Version : 1.04
In/Out Width : 4-bit / 4-bit
Multiplier : 2x
Speed : 8x 66MHz (528MHz)
I/O Queue Depth : 9 request(s)
Logical/Chipset Memory Banks
Bank 0 : 512MB DDR2 4-4-4-7 3-11-4-2 2T
Bank 1 : 512MB DDR2 4-4-4-7 3-11-4-2 2T
Bank 2 : 512MB DDR2 4-4-4-7 3-11-4-2 2T
Bank 3 : 512MB DDR2 4-4-4-7 3-11-4-2 2T
Integrated in Chipset : Yes
Shared Memory : 32MB
Supported Memory Types : ECC DDR DDR2
Channels : 1
Bank Interleave : 2-way
Memory Bus Speed : 2x 267MHz (534MHz)
Maximum Memory Speed : 2x 400MHz (800MHz)
Multiplier : 8/6x
Width : 64-bit
Refresh Rate : 21.44µs
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 4.17GB/s
APIC 1
Version : 0.03
Speed : 17MHz
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module
Manufacturer : Patriot Memory
URL : http://www.patriotmemory.com/
Model : 6400LL Series
Extended Information : mVNP 3
Type : 1GB DIMM DDR2
Technology : 16x(64Mx8)
Speed : PC2-6400U DDR2-800
Standard Timings : 5-5-5-16 3-21-6-3
Version : 1.02
Memory DC Line : 1.80V
Timing @ 400MHz : 5-5-5-16 3-21-6-3
Timing @ 267MHz : 4-3-3-10 2-14-4-2
Timing @ 200MHz : 3-3-3-8 2-10-3-2
Enhanced Performance Profiles : Yes
Profile @ 400MHz: Optimal : 4-4-4-12 X-20-24-X 2T 2.1V
Memory Module
Version : 1.02
Environment Monitor 1
Model : ITE IT8718F LPC
Version : 1.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 47.00°C td
CPU Temperature : 24.00°C
Cooling Device(s)
Auto Fan Speed Control : No
System Fan : 3027rpm
CPU Fan : 3947rpm
Voltage Sensor(s)
CPU DC Line : 1.23V
Aux DC Line : 1.78V
+3.3V DC Line : 3.33V
+5V DC Line : 5.05V
+12V DC Line : 11.61V
-12V DC Line : -0.92V
-5V DC Line : -6.72V
Standby DC Line : 4.60V
Battery DC Line : 3.20V
System Bus(es) on Hub 1
Version : 2.10
System Bus 0 : PCI
System Bus 1 : AGP
Multiplier : 1/6x
LPC Hub Controller 1
Model : ECS VT8237 PCI to ISA Bridge
OEM Device Name : VIA VT8237 PCI to ISA Bridge
Revision : A1
ACPI Power Management Enabled : Yes
Delayed Transaction Enabled : Yes
LPC Legacy Controller 1
Type : ITE IT8718F
Version : 0.18
Number of Enabled Devices : 5
Disk Controller
Model : ECS VIA SATA RAID Controller
OEM Device Name : VIA VIA SATA RAID Controller
Interface : ATA
Revision : I1
Channels : 4
Disk Controller
Model : ECS VT82xxxx EIDE Controller (All VIA Chipsets)
OEM Device Name : VIA VT82xxxx EIDE Controller (All VIA Chipsets)
Interface : ATA
Revision : A7
Channels : 4
Audio Device
Model : ECS K8M800-M2 (V2.0) onboard audio
OEM Device Name : VIA VT8233/A AC'97 Enhanced Audio Controller
Revision : G1
Type : AC '97
Version : 2.04
Audio Codec
Model : Gammagraphx 0000h
Revision : A1
Version : 2.04
Audio Codec
Revision : A1
Version : 2.01
USB Controller 1
Model : ECS VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
OEM Device Name : VIA VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Revision : I2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Revision : I2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Revision : I2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Revision : I2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : ECS VT6202/12 USB 2.0 Enhanced Host Controller
OEM Device Name : VIA VT6202/12 USB 2.0 Enhanced Host Controller
Revision : I7
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
SMBus/i2c Controller 1
Model : VIA VT823x SMBus
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 14kHz
Expansion Slot(s)
AGP : AGP 32-bit +3.3V Shared PME Half-Length Used
PCI1 (1h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI2 (2h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI3 (3h) : PCI 32-bit +3.3V Shared PME Half-Length Available
Port Connector(s)
J1A1 - PS2Mouse : Mouse / PS/2
J1A1 - Keyboard : Keyboard / PS/2
J2A2 - USB1 : USB / USB
J2A2 - USB2 : USB / USB
J4A1 - LPT 1 : Parallel Port ECP/EPP / DB-25 pin male
J2A1 - COM A : Serial Port 16550A / DB-9 pin male
J6A1 - Audio Mic In : Audio / Mini-jack
J6A1 - Audio Line In : Audio / Mini-jack
J6B1 - AUX IN : Audio / CD-ROM Sound Input
J6B2 - CDIN : Audio / CD-ROM Sound Input
J6J2 - PRI IDE : ATA
J6J1 - SEC IDE : ATA
J4J1 - FLOPPY : Floppy Disk
J9H1 - FRONT PNL : 9 Pin Dual Inline
J1B1 - CHASSIS REAR FAN : None
J2F1 - CPU FAN : None
J8B4 - FRONT FAN : None
J9G2 - FNT USB : None
J6C3 - FP AUD : None
J9G1 - CONFIG : None
J8C1 - SCSI LED : None
J9J2 - INTRUDER : None
J9G4 - ITP : None
J2H1 - MAIN POWER : None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2507 : Mainboard has too few memory slots. Upgrading the memory may be difficult or expensive.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
redduc900
Inactive Moderator
Portland, OR
Set the DRAM Frequency to 400MHz, and the four primary timings to 5-5-5-16 (DRAM CAS# Latency - set to 3.0/5, DRAM Bank Interleave, Precharge to Active (TRP), and Active to Precharge), along w/ the Memory Voltage to 1.85 - 1.9V. And I don't see anywhere in the Sandra printout you posted which CPU you're running, so assuming a default FSB of 200MHz w/ the DRAM Frequency set to 400MHz, the resultant FSB : DRAM ratio would be 1:2 (200 / 800 MCH Strap) for an effective 800MHz DRAM frequency.
