help with water block!! please help
jfarrar
loughborough
hi have just purchesd my third gtx 480 to tri sli
and on my other two i have the xspc razor 480 water block
and i have looked high and low to get another one but to no avail
i even contacted xspc to be told that they have been discontinued
so my question is if i buy a diffrent waterblock can i still use a vga water block bridge as some look like they wont line up
can anyone give me some help on which other waterblock could possably fit and if it cant happen how could i link them up with diffrent parts
cheers
p.s here is a few pics of my pc
so far i have been working on it for 2 months
photo.php
photo.php
photo.php
http://www.facebook.com/photo.php?f...0705678740548.705852.643540547&type=1&theater
You mean like this one? http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=27996
Since the cards are so close together, having them not line up might create other issues. But, I would check the link I gave to see if that is what you need.
The images in your post are not functional. I would suggest using a good image host that doesn't require you to login, such as Imgur or Photobucket.
EDIT: SVC has one, as well: http://www.svc.com/rzr480.html
Both vendors are very reputable.
