I have a slight problem with my newly built FX-8350 setup.
I just upgraded to amd setup from my trusty Q6600.
My water cooling just does not want to keep up with the 8350.
I did some testing and pretty much any overclock resulted my chip to slowly build up heat till around 65c-70c socket temp where I kill the stress. Core temps are 8-12c behind that. Ambient is around 18c.
Idle temp is as I type 36c at 4.4Ghz and 1.38 volts (Volts are up just for testing)
Yesterday I thought my installation was bad so I pulled the block off and discovered perfect contact with all of the cpu covered in thermal paste with no overflow.
Now I am out of options and wondering whats going on.
Only thing that comes into mind is that either my rad is covered in some type of crp inside or that my recycled fans aren't powerful enough to cool the water.
Just for comparison my Q6600 was clocked 3,4Ghz with idles of 25c average and 54 load and had an older EK supreme block that I know had some gunk in it. ( These are core temps )
Here is my current setup:
-FX-8350
-EK Supermacy copper-plexi
-Gelid GC-Extreme -Tpaste
-Swiftech mcp655-B - pump
-HWlabs GTX360 extreme - 360mm radiator
-Three noctua case fans on rad
-FX-8350
