Help With Windows 7 Upgrade
LilBuddy
Irving, Tx
I'm working on installing Windows 7 Upgrade from XP Pro. I have XP on a 72gb RAID setup and I don't want to lose it. I am trying to install Windows 7 on to a 640gb hd. When I do the upgrade what will happen to my old XP setup on the 72gb drives? After installing can I dual boot into the Windows 7 on the 640gb or the XP on the 72gb?
johnz
I don't know all the ramifications of running RAID as I never have. Typically what will happen with regular drives is Win7 will overwrite the XP bootloader, and you'd be able to dual boot using Win7's bootloader. I don't /think/ RAID will affect that, but maybe someone more knowledgeable will chime in.
nightelph
SoCal
A surefire way to protect your raid array is power off and unplug the sata cables to your raid drives, and boot and install Win7. Hook it all back up later.
LilBuddy
LilBuddy
Irving, Tx
Well since it is an upgrade I have to have the XP drive on there so it can verify that I have an existing copy.
nightelph
SoCal
Lol, whoops. I missed that its an upgrade version. Windows 7 can't perform a traditional upgrade from XP, only Vista and up.
LilBuddy
LilBuddy
Irving, Tx
Well my concerns are:
1) Will the Windows 7 install format my old XP drive even though I'm installing 7 on a different drive
2) Will I still be able to use XP on the other drive in case I don't like 7
LilBuddy
LilBuddy
Irving, Tx
Well I got to the first restart with Windows 7 and stopped it there to find out. I unplugged the drives and the boot wouldn't happen. I guess the boot record is on the RAID setup for the Windows 7 install. I put the drives back in and a boot menu came up to let me choose Older Windows version or Windows setup. So far so good. Back to installing later I guess.
SteveLord
Isn't it kind of late to "test" windows 7? I mean, its been available in various formats for almost a year or something. If you really wanted to check it out, you'd have done that...or install it on a virtual machine. Coming from XP, I'm not sure what there is that you woudn't like. Not having to supply a floppy disk for basic SATA drivers is a huge bonus over XP in itself.
LilBuddy
LilBuddy
Irving, Tx
Well I love XP and if what I do on my current OS won't work on 7 I'm not going to be happy with it.
LilBuddy
LilBuddy
Irving, Tx
Well I'm in Windows 7 for the first time. My first impression is it is exactly what MS should have done after XP. It seems like they took all the good stuff of XP and added the flash of Vista.
SteveLord
Thats how I describe it to everyone. The bells and whistles of Vista with the speed of XP.
