to completely remove f@H use the unnistal if you were using the gui, if you were using the console delete the folder containing the client and pertanent files.
the client you will need for a duallie is the text only client. Download a fresh client to a a folder and then another fresh client to the second folder, make sure not to copy the client from one folder to the other.
here is a quick setup for each client:
now start the first one and go through the config and then into advanced option. go all the way through and in the last field put "1" for the machine ID.
then start the second one and go through the config and then into advanced option. go all the way through and in the last field put "2" for the machine ID. make sure you change this because the default is one.
User name: put the name you want to fold under here (anyname)
Team Number: 32
Ask before fetching/sending work: put "no" if you have a 24.7 connction and "yes" if you have dial up
Use proxy: no (unless you are at a college that has one or something of the sorts)
Change advanced options: yes
Core Type: fah
Core Priority: idle
CPU usage requested: 100
Disable highly optimized assembly code [no] (no/yes)? no
Machine ID: 1 <-- this is the field that has to be different for each client a 1,2,3, or 4
if it doens't connect right away no worries, stanford has been having some load issues lately that they are trying to get worked out due to the huge influx of users.
FOLD ON
NAS
